10 years agoRunning a console executable from a tcl script
Hi there I am attempting to call a console executable file from a tcl script that should run before every compile. Here are a few iterations that I have tried, but nothing seems to make the tcl...
10 years ago "qexec" is the command you should be using, and it works fine. You will need to supply more information about what doesn't work. Do you need to specify the path to the executable, or make sure your PATH includes a .dll it depends on?
