hamze60
7 years agoRun OpenCL kernel on two heterogeneous devices.
Hello, As I read in the programming-guide, it seems that it is possible to have 2 parallel heterogeneous devices (such as two separate FPGA boards) to run a single kernel. I guess in that case some ...
hamze60
7 years agoThank you!
Actually I already have a software golden model to compare with my OpenCL result. The software is almost very similar to OpenCL code, and I also accelerate it with OpenMP.
However, as I wrote, I wanted to have it in an OpenCL style, to have a comparison (for academic paper) between FPGA OpenCL and CPU OpenCL. Sometimes I want to divide my problem on multiple devices, including FPGA and CPU. If intel OpenCL for FPGA, does not support this directly inside same tool, I think I need to use intel's another tool https://software.intel.com/en-us/intel-opencl
I will test it in 1-2 days to see.
