9 years agoRun fitter only
With Quartus 16.1 I often run into the situation that Quartus marks the "Analysis & Synthesis" step in the Task window as "needs to run"/dirty (with a question mark) even though I have not changed th...
9 years agoI just realized that, when in the situation described above, the fitter can be started through Processing > Start > Start Fitter without triggering Synthesis again.
