11 years agoRTL Viewer
Hi. If I have one file written in VHDL with two different architectures could I see in RTL Viewer structure for each architecture? or the architecture shown in rtlviewer wil be randomly selected b...
11 years agoLook up how to write configurations. You can put them in a separate file to control which entities use which architecture.
I suggest you stop using separate architectures. Your other posts also suggest you are trying to write code against convention. If you want to raise issue with the way the tools work, you need to be raising the issue direct with altera.
