11 years agoRTL Viewer
Hi. If I have one file written in VHDL with two different architectures could I see in RTL Viewer structure for each architecture? or the architecture shown in rtlviewer wil be randomly selected b...
11 years ago@Tricky, you understand . only one architecture but which one, it seems it uses one that latter in the file.
to get the second you should use another entity where you instained two componets. Is it convenienced? Research/design cycle becomes longer at this stage - to get rightfully adjusted vhdl code. As alternative - we all together pointed it out in the thread. We should think of "when your experienced you don't bother with such question 'how to' cause you know time-prooven designs"
