11 years agoRTL Viewer
Hi. If I have one file written in VHDL with two different architectures could I see in RTL Viewer structure for each architecture? or the architecture shown in rtlviewer wil be randomly selected b...
11 years agoarchitecture is selected when you instantiate the entity. If you do it via a component you need to use a configuration to select the appropriate architecture
component my_comp is ....
for all: my_comp
use entity work.my_ent(arch_sel);
Or better, use direct instantiation: inst1 : entity work.my_ent(arch_sel); If you have two architectures at the top level, apart from asking why, I dont actually know how Quartus behaves. Multiple architures, when used, are only usually used for differentiating a simulation model of an entity verses a RTL implementation. I have never used multiple architectures and it is highly discouraged in industry. If you want different behaviours then create different entities (or use generics to control behaviour).
