RTL Text Editor -> how to use both Editors (built-in & external)?
Hi All,
Usually I'm using an External Text Editor for RTL coding, but sometime I need the built-in Quartus RTL Text Editor in order to insert the Code Templates, etc.
As for the External Editor, I've defined it in the Quartus Options as a Preferred Text Editor. But how can I launch separately the Quartus' built-in Text Editor as well?
Thank you!
- ShengN_altera
Based on what I know, Quartus' built-in Text Editor can't be launched stand-alone.
You can detach the text editor but Quartus software need to be opened at the same time.
Sheng
- amildm
Contributor
No problem having the Quartus open at the same time while working with built-in Editor, but how can I open files with the built-in Editor when it's detached?
It seems it's impossible to open the files with the built-in Editor when it's detached.
- ShengN_altera
I think the feature that best suits your description is in detached Text Editor, go to Edit -> Insert File. You can't open another file directly within detached Text Editor since the detached Text Editor is for you to edit a specific file.
Sheng
