8 years agoRTL module crashes computer
I have a purely combinatorial RTL module as part of my OpenCL pipeline. The design compiles without problems or warnings. However, when executing the program, it first stalls for a few minutes, then the entire computer hangs and requires a manual restart. I can't make sense of this because: - Simulating the verilog itself works. - The design has no internal states and it's stall free with a fixed (0) latency. - Just using a simpler (but also combinatorial) design without touching any of the other code does not show the problem. - Status flags iready/oready/ivalid/ovalid are not used (just routed through) - The output of the RTL module just gets transferred back to the host (no further computation depends on it). I'm using the 16.1 SDK with the DE5a-net board. Any suggestions on how to debug this would be appreciated! Thanks, HannoNo RepliesBe the first to reply
