10 years agoRISC 16 sequential implementation in vhdl
I am working now on implementing a 16 bit RISC CPU in VHDL, the instruction set consists of 8 instructions 16 bits each. the architecture of the data path and instruction flow is attached , i need...
10 years agoThis is looks quite interesting, however it will be good if you try to explain more for what you plan to do. are you doing something liek this?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&uact=8&ved=0ahukewix2rgfpvtjahvici4khwp1cwyqfghjmac&url=http%3a%2f%2fwww.eng.auburn.edu%2f~agrawvd%2fcourse%2fe6200_spr12%2fproject%2f5200_6200project_spring2012.pptx&usg=afqjcne3mlgbupsqjtcpjrs1qe5nslge8a&bvm=bv.110151844,d.c2e
