18 years agoRing Oscillator Help!!!
Hello.I am from Greece.And i have find this forum today.I must design a project at university, But i have a problem.The project is to make Capacitance to Digital Conversion, so i must design a logic circuit and measure variable capacitors.I was thinking to create a ring oscillator and to connect a variable capacitor between ring oscillator and ground.More capacitance ,lower frequency.The problem??? The Ring Oscillator frequency without capacitor is at least 125Mhz very HIGH!!! I believe that the solution (slow down frequency) is to add more stages (for example 101,1001) but Quartus 7 web edition optimize my design and cancel all of the inverters.The frequency of a ring oscillator general is:
Fmax=1/n*Td n:stages R.O. Td=Time Delay of each inverter I use UP2 programmer in MAX fpga. HOW can i disable optimization??????????? Thank you!!!!
