17 years ago --- Quote Start --- May I ask what logic that is entirely unattached to anything else in a design is good for? --- Quote End --- You may safely assume that I'm up to no good. ;) --- Quote Start --- Some days ago I tried to fill up an FPGA up to 100% LE usage by implementing weird logic connected to nothing. The only way to have the logic really be implemented was to connect it to pins. --- Quote End --- I've found different results depending on the vendor tools (i.e. Xilinx), but in this case virtual pins also do the trick, as pointed out by Rysc above.
