11 years ago
Resetting an array in verilog
What's the best way to reset a 32x32 array when using the Quartus synthesis tool or any other synthesis tool for that matter. I used the following
always @ (posedge clk or posedge rst)
if (rst) begin
for (index_1 = 0; index_1 <= BUF_LENGTH ; index_1 = index_1 + 1)
buffer_1[index_1] <= 0;
end
where BUF_LENGTH = 31
    Is buffer meant to be inside a ram? Using an async reset will mean it can never be a ram, as ram cannot be reset.
    But otherwise yes, a for loop will do it.
    Btw, your array is only 1D looking at your code.
    --- Quote Start ---
    --- Quote End ---
    Thanks for the response. It's not meant to be in a RAM. I need to use Thirty two 32-bit registers and rather than define each one of them an array seemed to be the best way to do it.
    I'm assigning all 32'bits to 0 on reset so
    buffer_1[index_1][31:0] <= 32'b0;
    Was the lack of the [31:0] that led you to believe its a 1D array or am I making a syntax error?
    No, I read it as 32x32 array N bit values, hence my misunderstanind.
    32'b0 shouldnt be needed, it should just work with 0.
    In my mind you should use BUF_LEGNTH = 32, as this matches the reality of the situation (more self documenting) and use BUF_LENGTH-1 as the bounds for the loop.
    Remember that loops unroll during synthesis into parrallel hardware, so just imagine your circuit of 32x32 parrallel registers.
