11 years agoRequest for help in VHDL troubleshooting
Hi all, I am a new to programming of VHDL to FPGA. Recently tried experimenting with a code from a book and during simulation, it was functioning perfectly. However after i programmed into...
11 years agoHi Tricky and Daixiwen,
I have tried both the waveform simulation and the signaltap. Noticed that the default state is 'ABout' and it is alway in default state even though i tried triggering the sensor 1 and sensor 2. Rightfully when sensor 1 is a high then the state should have switch from ABout to Ain. Yet both ABout and Ain are activated. In this case, what will be the state that the chip is in?:confused:
