Altera_ForumHonored Contributor14 years agoreport timing with Tcl in QuartusII 11.0 Hi: I'm trying to report timing with Tcl in QuartusII, first I open a project and constraint the clock about 125MHz, after compile the project, I want to see the actual fmax, I use Tcl to repor...Show More
Altera_ForumHonored Contributor14 years agoOK, thank you for reply , the problem is resolved. The command in QuartusII 8.1 is OK
Recent Discussionsram retimingReset Release IP for Agilex needs Stratix 10 device files installed!Licensing ‘Know-How’ GuideTiming analysis - long combinational pathInvalid license key (inconsistent authentication code)
