9 years agoReplacing a process with 1-port RAM
i have process I need to now implement as ROM. process (count, outi, run) --converter
begin
if (run = '1') then -- run is a physical switch
case count is -- count ...
9 years agoYour "current_clk" is a logic generated clock, because you used logic to generate a clock
Much better to use clock enables instead.
