9 years agoReplacing a process with 1-port RAM
i have process I need to now implement as ROM. process (count, outi, run) --converter
begin
if (run = '1') then -- run is a physical switch
case count is -- count ...
9 years agoCount doesnt have an initial value, or a reset value, hence it will initialise (in simulation) to 'U'
You also have other issues: 1. You should create logic divided clocks- they are prone to timing issues on hardware 2/ do not use "and" with the clock 3. its better to separate asynchronous and synchronous logic into different processes.
