9 years agoReplacing a process with 1-port RAM
i have process I need to now implement as ROM. process (count, outi, run) --converter
begin
if (run = '1') then -- run is a physical switch
case count is -- count ...
9 years ago --- Quote Start --- Without seeing the code, it is impossible to say what is wrong. --- Quote End ---
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity school is
Port ( CLOCK_50 : in std_logic;
run : in std_logic;
dir : in std_logic;
step : out std_logic_vector (1 downto 0);
led : out std_logic_vector(3 downto 0);
slow_fast : in std_logic
end school;
architecture Behavioral of school is
signal divider : std_logic_vector (22 downto 0);
signal count : std_logic_vector (1 downto 0);
signal current_clk : std_logic;
component ROM IS
PORT
address : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
clock : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
wren : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (3 DOWNTO 0)
END component;
begin
U1 : ROM PORT MAP
clock => current_clk,
address => count,
q => led,
wren => '0',
data => "0000"
process (divider, CLOCK_50)
begin
if rising_edge(CLOCK_50) then
divider <= divider + 1;
end if;
end process;
process (run, divider, current_clk, dir, count, slow_fast )
begin
if slow_fast = '1' then
current_clk <= divider(0);
else
current_clk <= divider(1);
end if;
if (rising_edge(current_clk) and run = '1') then --
case dir is
when '0' =>
count <= count + 1;
when '1' =>
count <= count - 1;
when others =>
count <= count + 1;
end case;
end if;
end process;
step <= count;
end Behavioral;
