9 years agoReplacing a process with 1-port RAM
i have process I need to now implement as ROM. process (count, outi, run) --converter
begin
if (run = '1') then -- run is a physical switch
case count is -- count ...
9 years agoI read part of it a while ago, guess i forgot about.
I found this --http://www.alteraforum.com/forum/showthread.php?t=5958-- all I actually needed to do was use component instantiation and port map to connect the ROM to the main file. Thank you for your help.
