9 years agoReplacing a process with 1-port RAM
i have process I need to now implement as ROM. process (count, outi, run) --converter
begin
if (run = '1') then -- run is a physical switch
case count is -- count ...
9 years ago --- Quote Start --- If indeed you want to use the 1-port RAM as a ROM, you'd need to remove your decoder logic (the case statement) and instantiate the RAM in your design, attaching count to the address input of the RAM and outi to the output of the RAM. --- Quote End --- You can infer a ROM from decoder logic, if it is clocked. See "inferring ROM" from the Quartus HDL coding guidelines
