abeli1
8 years agoReplace Stratix V C2 speed grade 0.90V on I2L 0.85V
Good afternoon colleague. I want to replace the 5SGXMA7K2F40C2 chip on my board. 0.9v VCC. I have is similar 5SGSMD5K2F40I2LN, but it is 0.85V VCC. In Stratix V datasheet says: "C2L and I2L can al...
Vicky1
8 years agoHi,
Apologies for the late response.
we can replace with these Key factors to keep in mind, first make sure that Vcc, Vccio, currents and bank voltages are kept same or are well within the devices limits. The next factor would be the pin counts/pinouts – apart from the IO pins, the CLK/RESET/VCC/VccIO pins , configuration pins should all match up and both devices should be pin-to-pin compatible. Then these two devices can be swapped between each other.
Best Regards
Vikas Jathar
