12 years agoRelease resources
Hi, I'd like to understand release and acquisition of resources by the Altera OpenCL platform more clearly. I'm trying to be very careful to release all acquired resources (command queues, kern...
8 years agoI believe I´m facing a similar problem.
The difference is that I have only two kernels. And they are called inside a for loop. I´m freeing each vector after each use in the loop. However, it seems to have an upper limit of how much memory can I allocate in total.for(int j = 0; j < REPEAT ; j++) {
void *rand_input = NULL;
posix_memalign(&rand_input, AOCL_ALIGNMENT,sizeof(float)*SIZE);
memcpy(rand_input, output, sizeof(float)*SIZE);
cl_mem input_buffer = clCreateBuffer(my_context,
CL_MEM_READ_WRITE | CL_MEM_COPY_HOST_PTR,
sizeof(float) * SIZE,
rand_input,
&status);
free(rand_input);
free(output);
} This is the error message I get when launching the kernel. Context callback: Could not allocate a buffer of the specified size due to fragmentation or exhaustion Context callback: Could not map host buffers to device
