9 years agoRegister using component and port maps
Hi, I am building a 32 bit register using a 8-bit register as a component. However, I am stuck at port mapping the 8-bit register correctly, any tips/help would be appreciated.
my code so far: ----BITSTORAGE---- Library ieee; Use ieee.std_logic_1164.all; Use ieee.numeric_std.all; Use ieee.std_logic_unsigned.all; entity bitstorage is port(bitin: in std_logic; enout: in std_logic; writein: in std_logic; bitout: out std_logic); end entity bitstorage; architecture memlike of bitstorage is signal q: std_logic := '0'; begin process(writein) is begin if (rising_edge(writein)) then q <= bitin; end if; end process; bitout <= q when enout = '0' else 'Z'; end architecture memlike; -------------------------------------------------------------------------------- ----8-BIT REGISTER---- Library ieee; Use ieee.std_logic_1164.all; Use ieee.numeric_std.all; Use ieee.std_logic_unsigned.all; entity register8 is port(datain: in std_logic_vector(7 downto 0); enout: in std_logic; writein: in std_logic; dataout: out std_logic_vector(7 downto 0)); end entity register8; architecture memmy of register8 is component bitstorage port(bitin: in std_logic; enout: in std_logic; writein: in std_logic; bitout: out std_logic); end component; begin c0: bitstorage port map(datain(0),enout,writein,dataout(0)); c1: bitstorage port map(datain(1),enout,writein,dataout(1)); c2: bitstorage port map(datain(2),enout,writein,dataout(2)); c3: bitstorage port map(datain(3),enout,writein,dataout(3)); c4: bitstorage port map(datain(4),enout,writein,dataout(4)); c5: bitstorage port map(datain(5),enout,writein,dataout(5)); c6: bitstorage port map(datain(6),enout,writein,dataout(6)); c7: bitstorage port map(datain(7),enout,writein,dataout(7)); end architecture memmy; -------------------------------------------------------------------------------- ---32-BIT REGISTER--- Library ieee; Use ieee.std_logic_1164.all; Use ieee.numeric_std.all; Use ieee.std_logic_unsigned.all; entity register32 is port(datain: in std_logic_vector(31 downto 0); enout32,enout16,enout8: in std_logic; writein32, writein16, writein8: in std_logic; dataout: out std_logic_vector(31 downto 0)); end entity register32; architecture biggermem of register32 is component register8 port(datain: in std_logic_vector(7 downto 0); enout: in std_logic; writein: in std_logic; dataout: out std_logic_vector(7 downto 0)); end component; begin Implementing port map here end architecture biggermem; ----------------------------------------------------
