RPett4
7 years agoRegenerate .ip files automatically
In our version control tool, only the *.ip files were checked in. When I try to compile the design in Quartus, it complains that "The synthesis RTL for *.ip has not been generated. Generate the synth...
- 7 years ago
There is a option for you,
You can go to assignment -> settings -> IP settings. Check which setting you will need to turn on.
KennyT_altera
7 years agoYes, it should be. what you can do is archieve the project to *.qar files. Can unarchieve it to check the setting again.
If it does not save, let me know as it would be a bug.
