RPett4
7 years agoRegenerate .ip files automatically
In our version control tool, only the *.ip files were checked in. When I try to compile the design in Quartus, it complains that "The synthesis RTL for *.ip has not been generated. Generate the synth...
- 7 years ago
There is a option for you,
You can go to assignment -> settings -> IP settings. Check which setting you will need to turn on.
KennyT_altera
7 years agoAny update?
- RPett47 years ago
This is a pretty good solution, and it worked. Does this setting get saved into a project file? The reason I ask is that if I build on my own computer, it works fine since I have already changed the setting in my instance of Quartus Prime. But if someone else tried to compile the project on a different computer, my worry is that it would fail and it is possible that they would not know that this setting needs to be changed.
