VGopa7
6 years agoReg: Use ip-generate in Intel Quartus Pro When i use ip-generate in Intel Quartus Pro, it gives error as "ip-generate is not recognized as an internal or external command" But the same command works for Quartus Standard version.
When i use ip-generate in Intel Quartus Pro, it gives error as "ip-generate is not recognized as an internal or external command" But the same command works for Quartus Standard version. What is th...
AnandRaj_S_Intel
6 years agoHi Venu,
use "quartus_ipgenerate" for Quartus pro.
please go through the previous two posts.
Anand
- VGopa76 years ago
Hi Anand,
I was referring to this command "ip-generate" to generate an IP using the script from the command line interface, Below is the link which works for Quartus Standard
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd12182013_862.html
I need the equivalent command for the Intel Quartus Pro.
The "quartus_ipgenerate" does not work in Quartus Pro
Venu
