VGopa7
6 years agoReg: Use ip-generate in Intel Quartus Pro When i use ip-generate in Intel Quartus Pro, it gives error as "ip-generate is not recognized as an internal or external command" But the same command works for Quartus Standard version.
When i use ip-generate in Intel Quartus Pro, it gives error as "ip-generate is not recognized as an internal or external command" But the same command works for Quartus Standard version. What is th...
AnandRaj_S_Intel
6 years agoHi Venu,
The quartus_ipgenerate <project name > [options] command allows you to generate IP components or a Platform Designer system in your Intel Quartus Prime project.
Refer section 6.9 in user guide.
Anand
VGopa7
6 years agoHi Anand,
I just want to generate the ip file (.ip file) in the specified location.
The "ip-generate" is used to generate the IP variation file (.ip file) in the specified location in Quartus Prime
But the same doesn't work for Quartus Pro.
I think the "ip-generate" is replaced with some other command in Intel Quartus Pro,
I observed that the "ip-generate" is not present in the installation folder of Quartus Pro.
What is the equivalent command used in Intel Quartus Pro ?
Venu
