Altera_ForumHonored Contributor14 years agoReg and Wire What is the diffrence between Verilog reg and wire? Example: wire abs_select_high; reg int2_d;
Altera_ForumHonored Contributor14 years agoreg is registerd wire isn't. Wire can't hold a value, only connect regs
Recent DiscussionsQuartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SGIs Quartus Prime Pro 22.4 Compatible with Stratix 10 NX Series Device?Timing analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_register
