18 years agoI've found a possible way around this......
I can use the Quartus II project that I've inherited, and within the Messages window pane, right-click, select Select All, and write the results to a .txt file. That at least gives me a general baseline to start from. I can then use the docs to edit the commands as I see fit. The only problem with this approach, in my situation anyway, is the design that I've inherited is less than desirable (e.g. best digital design practices were not followed, etc). So, while I'm trying to get things cleaned up (the schematic is ridiculous...), I'm also trying to learn the toolset. At least TimeQuest is similar to PrimeTime..... And the most startling thing of all.....there isn't a top-level testbench. It was never created and never used! :eek: Anyway, thanks for the help.
