9 years agoReducing memory replication
Hi, I'm working on an OpenCL kernel that is using a 2MB dataset and I've currently been reading in the entire 2MB into on-chip memory, performing the operations (random read/writes) and then outputti...
9 years agoLocal memory buffers need to be replicated by the number of accesses to those buffers to allow parallel access. With unrolling, unless the accesses can be coalesced, you further increase the number of accesses to the buffer and hence, increase the replication factor. To stop the replication you should avoid unrolling the loop. Loop unrolling without replicating the local buffer will not result in any performance improvement. Check "Intel FPGA SDK for OpenCL Best Practices Guide, 1.8.5 Optimize Accesses to Local Memory by Controlling the Memory Replication Factor" and "Intel FPGA SDK for OpenCL Programming Guide, 2.2 Kernel Attributes for Configuring Local Memory System" for more info.
