12 years agoIt means the given address is relative to the base address of a parent bridge.
On the "Address Map" tab, you will see the actual (absolute) base address of your component (the numerical value that would be in system.h of your BSP). http://quartushelp.altera.com/current/master.htm#mergedprojects/system/qsys/qsys_pro_connect_comps.htm
