14 years agoRecompile of design in Q11.0sp1 results in .SOF that will not load JTAG-ID mismatch
I am at a loss to understand why Q11.0sp1 is generating an .SOF which fails to load on a CycloneIII 3C16.
The error I keep getting is: Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020F20DD Error: Can't configure device. Expected JTAG ID code 0x020F20DD for device 1, but found JTAG ID code 0xFFFFFFFF. Error: Operation failed All I did was change some top level logic and recompile. I did nothing to modify settings. The previous design was created with 9.1sp2 and I imported it into 11.0sp1. It had been compiling fine. And now, not. I have re-checked the devices settings. I cannot find where Q11 gets this value 0x020F20DD from or why now it is failing. Any help would be much appreciated. Dave
