FRoth
7 years agoRecommended PC for Quartus Prime Pro compilations
What is currently the recommended PC system for fastest compilations (for Arria 10's)? We are aware of memory recommendations, but what about the relative importance of other parameters: number of ...
HRZ
7 years agoMy 2 cents:
- In practice you should not expect more than 4 cores to be efficiently utilized during placement and routing of one design. Hence, investing in more than 6 cores (to leave room for other work) is a waste of money unless you want to perform parallel compilations. In reality, you will very likely need to do parallel compilations so more cores will not hurt.
- The operating frequency of the CPU should be the first priority but if you want high core count, then you are limited to low operating frequencies.
- The cache size will likely make not much difference since memory usage is in the order of tens of GBs and the cache hitrate is likely not very good.
- Get the fastest DDR memory you can; however, if you go with a server CPU, you will be limited to slow memory modules (usually up to 2666 MHz).
- More memory channels means more memory bandwidth which can improve the speed of the "memory-intensive" process of placement and routing.
- CPU architecture will make little difference since there have hardly been any major architectural improvements in the past 5-6 years; however, going with the latest architectures is likely the best choice since you also get higher operating frequency and better memory controller.
For me, since I use OpenCL to create very large designs, the main bottleneck is the "memory size" since that is what limits the number of parallel compilations I can do per node. On a node with 256 GB of memory and 2 x 10-core modern Xeons I can only do 4 parallel compilations targetting Arria 10, or 5 targetting Stratix V. I still have unused cores in both cases but I cannot add any more parallel compilations becuase then the compilations will start crashing due to running out of memory.
