Recommended PC for Quartus Prime Pro compilations
The Compiler can detect and use multiple processors to reduce total compilation time. You specify the number of processors the Compiler uses. The Intel Quartus Prime software can use up to 16 processors to run algorithms in parallel.
Parallel compilation reduces the compilation time by up to 10% on systems with two processing cores, and by up to 20% on systems with four cores. When running timing analysis independently, two processors reduce the timing analysis time by an average of 10%. This reduction reaches an average of 15% when using four processors.
The Intel Quartus Prime software does not necessarily use all the processors that you specify during a given compilation. Additionally, the software never uses more than the specified number of processors. This fact enables you to work on other tasks without slowing down your computer. The use of multiple processors does not affect the quality of the fit. For a given Fitter seed, and given Maximum processors allowed setting on a specific design, the fit is exactly the same and deterministic. This remains true, regardless of the target machine, and the number of available processors. Different Maximum processors allowed specifications produce different results of the same quality. The impact is similar to changing the Fitter seed setting.
