FRoth
7 years agoRecommended PC for Quartus Prime Pro compilations
What is currently the recommended PC system for fastest compilations (for Arria 10's)? We are aware of memory recommendations, but what about the relative importance of other parameters: number of ...
FRoth
7 years agoThe knowledge base item is from 2013, I understand this as it is still valid for Quartus Prime Pro? Does it make sense to invest into more CPU cores? Could you please confirm or deny whether QPro fitter uses only a single core (as stated somewhere else on the forum)?
Does it make sense to have a CPU with four memory controllers instead of the usual two? Will this have significant impact on compilation time or does most of the computation happen in chunks of netlist stored in the CPU cache, so the DDR memory bandwidth is not that relevant to compilation time?
Thanks for all the answers :)
