13 years agoReading output signals feature in VHDL-2008 & Quartus
I have issue with reading outputs in VHDL-2008 code with Quartus. I made simple example which reads output signals inside process. Then i set VHDL standard to VHDL-2008 (in file properties as well as in global project settings). Compilation error appears:
Error (10309): VHDL Interface Declaration error in vhdl2008.vhd(16): interface object "q" of mode out cannot be read. Change object mode to buffer.I checked it with Quartus versions 11.1 and 12.1 (32 & 64 bit) with same results. At the same time the code is successfully compiled by Modelsim. What's wrong? I thought that reading outputs is one of the basic feature which is supported in new VHDL revision. library ieee;
use ieee.std_logic_1164.all;
entity vhdl2008 is
port (clk : in std_logic;
q: out std_logic := '0');
end entity;
architecture rtl of vhdl2008 is
begin
process(clk)
begin
if rising_edge(clk) then
q <= not q;
end if;
end process;
end rtl;
