13 years agoI meant same level (not same folder) i.e. your structure like this:
- quartus (folder - ModelSim(folder) - files(folder) then put mif in files folde1. so that way the path in Megawizard becomes: ../files/name.mif which is correct from modelsim as well. You may also just copy mif inside modelsim folder
