13 years agoIt is common problem when having mif file relative path determined from Quartus level (in megawizard) then moving to ModelSim the path may become wrong from ModelSim relative level.
The remedy is to make the path same from either Quartus or ModelSim folder i.e. put the mif at same level as both folders.
