Altera_ForumHonored Contributor15 years agoRead simulation output to Matlab Hi, Anyone can help regarding how to read out the vector waveform file simulation output so that I can use the output to plot using Matlab? Thanks you. Hope anyone can help Regards, ...Show More
Recent DiscussionsIs Quartus Prime Pro 22.4 Compatible with Stratix 10 NX Series Device?Timing analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_registerAutomatically added negative node for TDS output doesn't work with Agilex 5
