15 years agoFirst of all, thank you so much for your reply.
I save my vector waveform file into another file type called vector table output file (*.tbl). I get the list of of input and output values of my simulation. However, the value read out does not synchronous with the clock pulse positive edge. Several data were recorded in each clock cycle. How do I do the make sure the sample only be read out for each clock pulse. for instance, I want to record the data at each 10ns interval from 1715ns to 2355ns. May I know what do you mean by the command of textio? where to apply this command? Hope to receive your reply soon. Thank you.
