Altera_ForumHonored Contributor12 years agoRead from sd card an image on DE2-115 Hello I am writing a pure verilog code reading an image from sd card which i will show on display(vga). Can anyone help me with it i can't find the way to start. Thank you A.AShow More
Altera_ForumHonored Contributor12 years agoi also having a same problem. can you please send me those code to me
Recent DiscussionsIs Quartus Prime Pro 22.4 Compatible with Stratix 10 NX Series Device?Timing analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_registerAutomatically added negative node for TDS output doesn't work with Agilex 5
