Altera_ForumHonored Contributor12 years agoread data from file for implementation peace ! requesting some help with my vhdl code! I'm writing code for image processing, what I nead is read data(integer) from file (txt,xml or dat) to implemente the code in the board, the fi...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
