Hi.
Do this version need any license?
Thank you.
S_Dyn.
No, the web version of Quartus 13.0sp1 does not require a license. Just install and run. It supports the DE1 board directly.
- S_Dyn9 months ago
Hi.
I get the message when I open the QII.
Would I face the same issue where the .sof file is not generated after compilation because of the web version?
Thank you.
S_Dyn.- _AK6DN_9 months ago
Select the second option "Run the Quartus II software" when you install.
You don't need or want the subscription version which requires a paid license, and
I am assuming you are not using any purchased IP files so the third option does not apply.Once the web version is installed, it won't ask you again about licensing.
- S_Dyn9 months ago
Hi.
Thank you for the advise.
I have successfully install and run the software.
Now I need to try to compile a Verilog code and load the code onto DE1 board.
S_Dyn
