Vishnu_Ajith
19 days agoSynthesis error
I generated HDL file from qsys and did the compilation in Quartus. Following error log was found: Error(13224): Verilog HDL or VHDL error at altpcieav_256_rp_rxm_rdwr.sv(287): index 3 is out of rang...
sstrell
19 days agoDoes your Platform Designer system generate successfully when you generate it manually?
- Vishnu_Ajith18 days ago
sstrell Yes it does. Although some warnings were there it did generate. One more point to be added is the files were developed on 20.3 version and I am using 21.3. But I did see the synthesis report of previous compilation and it showed 21.3. Is the simulation version sensitive?
- ShengN_altera12 days ago
Hi
Any further update does your problem had been resolved?
