KCMurphy
3 years agoThe issue here is "optimization" which needs to be turned off for logic debug, and probably always in an FPGA design. For verilog, right click on a source, choose "compile properties" and check "use vopt flow" and maybe you want to select an optimization level under coverage. I believe that these settings are project wide. If you need to look into an Altera IP block, you may have to put a comile option into the msim_setup.tcl file. Haven't tied that.
Note: I solved this about a year ago and may be a bit fuzzy on the path.
