malayali
4 years agoQuartus Prime Software system debugging tool support
Hi ,
I'm using the System debugging toolkit from the Quartus prime software and changing Rx and Tx parameters for the DP 1.4 to test loop back, using Arria10 based on our own designed board. Pl cl...
malayali
4 years agoHi Goel,
Thank you for providing this useful information.
I noticed that when I first ran in High gain mode, no BER showed. However, if I switch from High gain to High datarate mode, there is no BER in Lower datarate (RBR), but if I switch back to High gain mode, the BER appears. While I was performing the test, I didn't shut the toolkit.
Does it because of a tool problem? Sometimes tools crash as well.
