TSege1's avatar
TSege1
6 years ago
Quartos Prime Pro 19.04 on Ububtu 16.04 LTS - Eclipse crashes on startup "free(): invalid pointer"
Hi All, I installed Quartos Prime Pro 19.4 on Ububtu 16.04 LTS. When i run Eclipse, i getting the next Error: OpenJDK 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was rem...
  • SThor8's avatar
    6 years ago
    Hi
    I have a similar error, my solution was to replace Quartus java engine with Java 8
    It must be java 8
    The following workaround seems to work, it essentially replace Quartus included java engine with Java 8
    cd ..../intelFPGA/20.1/quartus/linux64
    mv jre64 jre64_old
    ln -s /lib/jvm/java-1.8.0-openjdk-amd64/jre jre64
    the path to Java 8 jre might be machine specific, mine is at least placed there
