Porting from Xilinx to Altera
- 4 years ago
I believe I have provided the support/answer that you needed in order to proceed with your project. With that, this thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
Hi @Mathiazhagan,
I have attached the intel_project.zip in the ftp.
Please remind that the tool could only convert the design to Agilex device which is in Quartus Pro. If you plan to use in other Quartus version, you may try to open a new project and add the respective files.
Also Device xc7a35tftg256-1 is not supported. Some primitives/macros may not detected during the conversion.
You will need to check the x2i_primitive_lib.sv file to know which primitive has been blackbox and you will need replace it with an equivalent primitive.
Same goes to the IPs. You will need to instantiate the equivalent intel IPs. e.g. IOPLL, adder,
Richard Tan
Dear RichardTanSY
Am not able to view the zip file shared by you,
I have attached the screen shot of the filezilla for your kind reference
With Regards,
V.Mathiazhagan
