My signaltap test has some problem
The gap is normal behaviour. I test the example design with don't care triggering points and i get gap like below:
When I set the rising edge triggering points like below:
In first picture, there's no trigger point (don't care) so the 0 is at the beginning. In second picture, the rising edge trigger point is being set and the 0 is at the rising edge and there's waveform at the negtive time frame before 0.
The gap mean there's no waveform at that point. The gap will be reduced if the sample depth is reduced.
Your case most likely due to the trigger point (once per program) had been passed. May I know which triggering you expect?
Please check also the timing whether it's clean and whether the tapping signals having common sampling clock as mentioned by FvM
- xxiao1413 hours ago
it's timing problem, after I fixed the timing warnings, problem solved, thanks.
