I've been trying to simulate an IP core on Modelsim. The IP core I'm using is ALTFP_MULT IP core (floating-point multiplier), with double precision and an output latency of 5(the lowest latency...
Thank you so much for your reply! I tried to toggle the switch, with the following modified code, but still I have the same issue. Is there anything else that I've done wrong or maybe there's anything more I should add?
