modelsim.exe - System error because of MSVCR120.dll not found
- 4 years ago
Please checkout this link that I wrote on how to generate the Questa Intel FPGA Starter Edition license.
Richard Tan
Hello @RichardTanSY_Altera , thank you for your reply.
As per your suggestion, I downloaded Questa - Intel FPGA Starter Edition v21.2. I have setup the LM_LICENSE_FILE in Quartus.
Now I'm getting this error - " Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem."
I verified the environment variable settings and it has the license path as follows -
C:\intelFPGA_pro\21.2\questa_fse\win64\1-V48SFZ_License.dat
I ran the 'lmutil lmdiag' on the console (refer to the attached image)
Request you to suggest resolves for this issue.
